I am looking at purchasing the Arlo Pro 3 for home security, but do not wish to install the wireless ones. I would rather have a wired system to avoid from having to the change the batteries so often as I did with my previous Arlo system. Do the Arlo system come equipped with as a wired system vs a wirelss system?
I have not saw a wired system. I purchased the chargers/cables for mine separately. While they are not from Arlo they work perfectly. No matter where you get them make sure to get the ones for the Pro 3 or Ultra. The older ones will not work.
There are both indoor and outdoor AC power adapters for the Ultra/Pro 3 cameras. Check the product accessories here.
