Pro 3 Model FB1001 Cannot connect
Cannot connect no matter what I try. Get the chime and it searches for device then the X…
If your router lets you disable 5 ghz wifi, then try doing that before onboarding. Also make sure that the WiFi network is set to WPS2-PSK (AES) encryption.
If you are trying to onboard with your phone, you might also try onboarding from a PC (my.arlo.com).
