  • 1 Reply
  • 1030 Views
DotFitz
Cannot connect no matter what I try. Get the chime and it searches for device then the X…
If your router lets you disable 5 ghz wifi, then try doing that before onboarding.  Also make sure that the WiFi network is set to WPS2-PSK (AES) encryption.
If you are trying to onboard with your phone, you might also try onboarding from a PC (my.arlo.com).
  • 1 Reply
  • 1030 Views
