  • 1 Reply
  • 923 Views
Kdanny22
I have a Pro 3 floodlight mounted on the corner of my garage pointing down at my driveway.  At night, the video is often “hazy” if there is any moisture in the air.  It looks like it is a blizzard when it is really just misty air. Any suggestions?  I’ve attached a screenshot from a video of a fox crossing my driveway.
There's not much you can do.  You could maybe put something over the floodlight, to try to create some space in front of the lens that isn't misty.  That would shift the focus further out, which I think would help some.
  • 1 Reply
  • 924 Views
