The base station firmware update above keeps needing to be installed for four days in a row now (maybe longer, it's been 4 days since I've been keeping track). For some reason, I'm not able to view livefeeds for the cameras that are connected to this base station. I do still get notifications and recordings for those cameras but livefeed is not working. The base station light is also blinking orange-blue-orange-blue.
I have restarted the base station from the mobile app, unplugged / replugged my modem & router, and both cameras are connected directly to power. I also have the regular arlo subscription if that helps.
One other thing to note is that, when I manually go into the app and update the base station firmware, I'm able to view the camera live feeds for that day but, when I get up the next morning the same issue returns.
To be sure your camera can successfully receive the update, please follow these steps:
1. Fully charge the battery
2. Bring the camera close to your base station/router
3. Initiate the firmware update via the Arlo Secure mobile app and watch the LED behavior on the camera. You should see an alternating blue/amber LED. If you do not see this LED behavior, attempt the update again through the app.
