Does CVR need direct wiring? If so, what Arlo accessories can be used for direct AC power so I can use CVR?
Also, will using CVR give me much higher bandwidth usage to the point of a much higher internet bill?
Thanks for any replys
CVR requires the camera to be plugged into AC power since the battery simply can't last long when streaming constantly. Use the approved power adapters suitable for the location of the camera - outdoor adapter for outdoors.
The camera is constantly streaming so your Internet usage will definitely increase. If you're limited in any way, CVR likely isn't a good choice.
