Pro 3 - Blinking Blue No Charging
  • 2 Replies
  • 2202 Views
drewcam8888
My Arlo Pro 3 is connected to my station as I can see it in the app. As soon as I connect the charger the blue led blinks for a few seconds. Then stop for a couple seconds then repeats the blinking. Camera seems to be paired during all phases. Camera is not charging at all during these phases. Any ideas?
drewcam8888
It is charged now. At some point it started working overnight. I am using OEM cable and adapter so not sure what happened.
Shaun1234
Virtuoso
Virtuoso
Yes this particularly happens with after market charges.
Assuming you have the correct voltage plug etc these can be fussy on the magnetic connection, try wiping ends of lead and camera with a dry cloth and when you reconnect to give both ends a little push to ensure a good connection
drewcam8888
  • 2 Replies
  • 2203 Views
