phfisk,
What does it say? Could you provide a screenshot?
@phfisk wrote:
I have tried to attack a photo but says it does not accept jpeg?
Change the extension from jpeg to jpg.
Sounds like you don't have any subscription for these cameras. Any camera newer than the Pro 2 requires a sub for cloud recordings and use of zones when not connected to AC power. Do you have a subscription as found in Settings, Subscription? If not, you can remove any zones and have only local recordings when you enable it in the hub's settings.
Go into the camera settings, Video Settings and check for any zones that are defined. On the app, you should be able to swipe to the left to remove the zones.
