Phone connection
  • 1 Reply
  • 2609 Views
toffi24
Hello,
What accessories  i need to connect arlo pro3 camera which will be mounted on my boat ,very far from my house ,with  a mobile phone?
@toffi24 wrote:
Hello,
You'd need a base station that connects over ethernet to the internet.  Internet could be provided with a mobile router.  If the boat is within range of suitable wifi, you could potentially also use a wifi extender to provide the internet.  The router/extender and the base would need to be always on and powered.
An Arlo Go might be a better option.  It is battery powered, and connects to the mobile network.
Is the boat out of the water? If not, I am thinking you might get a lot of motion detection (especially if the boat is moored).  That could drain the battery quickly.
@toffi24 wrote:
Hello,
  • 1 Reply
  • 2610 Views
