Orange Light on Internet Connection
Hey can anyone help...
I have a VMB4000. It has been connected to my router for at least 8 months and all of a sudden the internet status went blank. I tried resetting and then it went amber. I have green for power and had green for cameras. I understand this means that it is not connecting to the router.
I have tried:
Re-setting the base station
Power off both base and wall
New Ethernet cable- that is known to be working.
Direct connection into the router
Factory reset (including removing my devices- which now I can't get back up)
So currently I have nothing as the base won't connect and the cameras have been removed.
Not too sure where to go from here apart from buying a new base as its clearly not working.
Any suggestions before I make the purchase?
Did you also try connecting the base to a different router LAN port?
