One kit of 3 camera, to seperate
I have 3 cameras set up at my main house, I wish to take one and install it at my cottage, is that doable to use one of the camera in a secondary location? If possible would I still see it on the Arlo app on my phone, would I need to create another account and switch from account to account to have access to both locations
merci
merci
You can keep the camera in the same account. There might be some ramifications with the subscription (if you have one). The new "Feed" experience being rolled out lets you specify the location. If you do that, you will need separate subscriptions for each location.
The current "Library" experience doesn't work that way - but I think everyone will end up on "Feed" sometime soon.
