Recording issue
  • 1 Reply
  • 1025 Views
sal61093
My Arlo Pro 3 system with base station is not recording. I have done everything to restart, reboot, reset multiple times with no luck.  When I click on Mode the only thing that shows up is my base station so I can't Arm my cameras.  They show as on-line and paired to the base station and are functioning perfectly otherwise but will not record.  Any thoughts?
When checking the Mode card you have to click on your base/hub to see the modes. This allows you to have multiple bases or WiFi-connected cameras.
  • 1 Reply
  • 1025 Views
