Since the new app has appeared. Nothing will connect. No camera views. Hub wants a password but is plugged into the hub
Message 1 of 2
672
You can't log into the hub since the security is set to prevent that. Have you looked at the Devices tab as well as Dashboard? If the devices are shown in the Devices tab, you can go to the Dashboard and add widgets for your cameras by using the "+" at the top.
Message 2 of 2
663
