Not recording
We have both restarted hubs with no change.
These are not cheap cameras and i feel like I've purchased cheap!
Quick question, I'm not sure if you have this issue, but I have had this occasionally but yesterday for one of my cameras it was happening most of the day then stop detecting motion. Then this morning started detecting a bit more normally, but will watch.
I noticed that sometimes my cameras record for 5 minutes straight even though the motion was only 10-30 seconds of activity. That happened very frequently yesterday for one of my cameras and then it stopped detecting motion for most things. I rebooted and it helped slightly for maybe 30 minutes and issue came back and didn't record for the whole night and then resumed again this morning a bit more normally. It happens to my other cameras occasionally too
I had one camera to completely stop recording Thursday morning. After I noticed that it missed everything for most of the day (I drove past the camera and walked past it several times) I went to the app to see if it would live view, which it did then everything started working again. I also noticed on the same camera that my wife left in our car the other day and the same camera never recorded her leaving or returning. This is not what I purchased these cameras for...… frustrating to say the least. I have a open case in progress for another problem, after that one is solved I'll look more into this problem.
We are opening cases for our individual cameras when clearly nothing we can do our end is going to help, this is all software issues or server problems arlo's end.
If we had our cameras in the wrong place restarting wouldn't help.
Same here. This morning the issue came back, where it missed majority of the motion. For me, it started about yesterday, where it was recording like 5 minute videos (usually it's only a short time frame depending on how long the motion lasts for). But yesterday it was recording 5 minute ultra laggy videos, then it just stopped recording entirely. I left the house in the morning and it record, but afternoon return was missed. Then basically the entire day and night's motion was just not detected at all. This morning was slightly better for like an hour then it came back.
This is so frustrating!
Hi! Just wondering if the two of you are having issues? Yesterday, one of my cameras started recording 2-5 minute recordings (despite motion only being under a min) then it stopped completely. I rebooted it last night and worked for like 30 minutes and didn't work all night. It just didn't record 😞
With my issue yesterday, I noticed it either didn't record, or it detected motion (with the orange motion turned on) but no notifications or recording. Arlo had an update for the app, and I updated but after that it doesn't let me turn off Arlo Smart.
Think I need to submit another case with Arlo again.
Strange you cant turn it off now
I'm not having any recording issues for now. I sometimes wish mine would record for a little longer. The majority of my recordings are 15 to 20 seconds. I have it set to record until motion stops which in a lot of instances is too soon as it instantly starts recording again. I really do not want to set it to record for a set length of time.
I'm still using smart notifications which works pretty good. Have you tried to edit smart notifications and dragging all the cameras to the deactivate smart notification section to turn them off?
Thank you very much for the quick reply! May I ask how you turned off your smart? I.e. to inactive or manually off for each option (i.e. motion, person, etc). I tried inactive and it doesn't detect anything at all. Then I tried turning off motion, person but requires me to leave at least one thing one and not everything off.
Thank you very much for your quick reply! I have tried that, but when it's inactive, it doesn't detect motion for me (or at least that is what happened when I last tried). But will try again!
This morning, it detected motion but no notification or library recording. Going to have to try opening another case for this 😞
Settings
Smart
The clicked edit at top right
The held the 3 dashes next to that camera and dragged down
I went into Settings, then
Smart, then clicked edit at top right corner, I then held the 3 dashes next to that camera and it dragged down into inactive or remove
Thanks so much! I'll give that a try. Submitted a new case with Arlo, who asked me to put the cameras all on balance between video quality/battery life and give that a try too. Will try both these out and see if it helps!
Thank you!
Just by way of an update. I have found that my cameras still miss recording to the cloud here and there but I've put an SD card in the base and I seem to get all the recordings I expect on that.
I had the same issue before! But haven't had the chance to check with my USB lately (because of a bigger issue where one of my cameras just stopped entirely). Have you reported this to Arlo Support? It is evident that the cloud is having some issues!
You do not need to physically download to view any of the videos. They should be viewable on the App itself without any downloading.
Sorry can't help you with that, I have smart turned off as it doesn't work for me
@Bluehawaii wrote:
Ok. So I got a subscription for 1 camera for Pro 3 n now it records! But I set 1 smart motion setting for “people” but it records the cars and tree branches!
With smart notifications you will not get notifications for unselected items but it will still give a recording that will be labeled. Activity zones is a different function and you should not get any notifications or recordings outside the zone you set up.
