  • 7 Replies
  • 2057 Views
Mikegsr66
Is it possible to not have a subscription with this combination? I am new and unable to figure out how to capture and retrieve video without a subscription for two camara units and a wireless front doorbell
dcfox1
@Mikegsr66 wrote:
I checked and it has an Arlo folder and Metadata,. 57Gb left. the drive is a PNY 64 GB USB 3.0 Flash drive 4K. I got the same result when using a USB 2.0 drive, Can't read.
I have the camara set to look at the base station.
Within the Arlo folder do you have any folders that are titled 000000, 000001 000002 or up in  there? That is where the recordings should be if it is recording.
7 REPLIES 7
The VMB4540 base supports direct access to local storage, so that is one option to eliminate the subscription.  It's not as easy to use (especially for remote access), and you can't access the local videos from your web browser.
But the wireless doorbell needs a subscription, because it can't be connected to your base.
https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i...
https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Mikegsr66
Thank you for the reply. I will get a subscription for the doorbell. The other two camaras, even though I have a drive plugged in always says Can't retrieve the videos. Any thoughts
Maybe try plugging the drive into a PC and see if anything is on it.
What drive are you using?
Mikegsr66
dcfox1
Mikegsr66
Yes, I drilled down and it loked like the recordings are there. Thanks for your help, but I decided to go ahead and subscribe, the non-subscription appears unreliable at best.
Too much hastle.....
dcfox1
Glad they were there. I personally think the Subscription is worth it with the limitations of local storage. I just use it for back up.
  • 7 Replies
  • 2058 Views
