For the last two days, I can not access my recordings on the base from any cameras and doorbell. I am still getting notifications and a snapshot, but no new or past recordings are available. Is this a ploy to make us subscribe? I have had the cameras a long time and have done all the trouble shooting tips to no avail.
@kvsqz511 wrote:I'm having the same issue. Also, want to know when or if they're going to allow the people, that have granted access, access to view the local storage ONCE THAT'S RESOLVED. Instead of trying to forcefully make us get us a subscription.
Or can I return?... after 3 months??
Depends on the retailers Return policy where you purchased it. Many are 30 days.
Anyone have issues with the App where your cloud/local storage option disappeared from library? I'm reading comments on Google Play that there's issues with the App. Anyone have a workaround? Cameras are useless unless I sign up for plan.
It's a bug in the Android 3.5.1 app, but not in the iOS app.
You can of course eject the USB drive, and review the recordings in a PC.
Defeats the purpose of viewing remotely while away.
Good that support/dev team is on it. Hope for a quick fix!
This issue has been resolved with the latest version of the Arlo Mobile App. Please make sure you have the latest version (3.5.2) downloaded and installed from the app store.
Thank you,
Just downloaded. Seems to be fixed
I am having a similar issue, I cant access local recordings from 1 of my 6 cameras. I do receive notifications in the app. When I try to go live it spins and spins, then timesout. My Arlo App is running 3.5.2_2835, the camera having the issue is one of the original 5 cameras. I also have a Pro 3 camera that is not on a subscription plan. Should I unpair and try to re-pair this camera.
Look under settings of your base and see if all your cameras are listed under devices. If not, add that camera
thank you, they are all listed. I am rebooting the base station, cant hurt. appreciate it
Reboot worked, thanks everyone.
If all else fails...uninstall and reinstall Arlo App...
Seems to be working.
Thanks.
Looks like the app update fixes the problem on my Android phone. SUPPORT had no clue how to fix it. Apparently they didn't know there is an app update. GOOD GRIEF!
Hi James
My Arlo on my I phone Mobile app showed 3.5 (2590), released July 8 2021. Does it considered as ver 3.5.2 ?
Jimmy
@Dziemvuong wrote:
Hi James
Jimmy
The app bug with direct access to local storage only affected Android, not iPhone.
Is your problem related to recording generally, or is it specific to direct access to local (usb or microSD) storage?
Please provide the update as soon as possible.
Run/Install the Play Store version with the Arlo Logo. If you find the correct one, it actually says Arlo App 3.5.3, When I did it, mine updated to version 3.5.3 on my Android Phone. It seems to work. My only complaint is the unimproved extremely long delay time between activity and alert (Latency).
