No acces to local records on local network
Since a cuple of months I have no longer acces to my local records when I am on my home network. Outside my home network I can acces my local records. I already have reseted the base and waited for new updates but with no succes.
9 REPLIES 9
Are you using a VPN at home?
No, I’m using port forwarding for acces outside.
Understood but folks sometimes use a VPN at home for work or other purposes.
Oké, no I don’t think I have VPN on my network. The thing is that before 07/2021 everything was fine. I could acces my local records from outside and when I was home on my LAN network. But suddenly I only can acces my local records from outside my network.
Long shot here - try rebooting both your router and hub, in that order.
Just done that but still no acces when on LAN. The strange thing is when I dissable port forwarding, I can acces my local records when I’ on my LAN…
Do you use an iPhone?
Just wondering, as we've seen a couple of other posts from iPhone users who are reporting the same thing.
Yes I use iphone with the latest update ios 15.1
