Motion notifications at smart hub base
My arlo pro 3 has been sending a push notification that there is motion at the smart hub every minute. What I've read so far is that some others are experiencing similar things. It seems this only started happening after my free trial of the subscription ended. Does anybody have any advice on how to fix this?
It is a "known issue". Arlo is on the case and promises to update us when it knows more.
Keep your eye on those messages.
Base Staion Motion Detected notifications - Arlo Community
Just another user
