They say there is nothing called a silly question, but....
On the Arlo app Devices Page under the Live Camera Feed, there are four icons.
Battery, wi-fi signal, audio detection and Motion detection.
On my app, the the battery, wifi and motion is "black" but not greyed out
The audio is greyed out.
Occasional the Motion detection turns yellow.
Is the Motion detection supposed to be constantly yellow, or is the "black" normal ?
Motion detect icon………
black when armed
gray when disarmed
amber when motion detected and usu recording ( from armed )
Thank you for your reply.
An observation though, if I select All Other Audio in Smart Alerts, the amber light on the Audio is constant on.
Would have thought the same would be the case for Motion.
Thank you
You could change the audio detection sensitivity in your modes and rules to see if that helps. Are you getting lots of videos labeled as audio detection?
A fair few especially when it is windy.
I'll give that a try,
Thank you
I have I’ll attach a pic if you can assist me I would appreciate your time.
-Sam
S1L3NT,
The icons showing white for you are considered black (you have dark mode enabled reversing the color scheme).
For more information, take a look here: What do the icons in the Arlo app mean?
