  • 2 Replies
  • 1106 Views
Pigcrazy
I have a VBM5000r5 base station.  I have inserted a 64GB micro card in the base station, but I keep getting an error message that the card needs to be at least 1GB.
does this card need to be formatted? If so, what format?
They are formatted FAT32 - the base can do that for you.
Usually your issue either means the card is defective or that it was pre-formatted with multiple partitions.  If you can connect it to a PC, then you can go into the Windows disk manager and delete all the partitions on it (and if you like, create a new one).  FWIW, Windows calls the partitions "volumes".
Pigcrazy
Thank you for your help.  I was able to format a card thanks to your help.
in the app under storage settings the following are now green:
Record Locally
overwrite automatically
direct storage access
the storage status is “ready”
under storage status the local storage status is “good”
available storage 9.41mb of 58.22mb
however, when I click on the library (it is on base station, not cloud since I canceled that subscription this week) I get the following message
“ videos stored on base station are not available. Please check your connection settings” with a “learn more and a cancel link.
I have the phone/app connected to the same WiFi that the hub is using.
thanks for any help
  • 2 Replies
  • 1107 Views
