Hi,
I've had a Pro 3 set up with 3 cameras since January. Everything was working fine until the battery ran low in one camera.
I have charged it up but when I have gone to view it it was offline. I removed and reconnected the camera but now it shows as poor bandwidth and is offline. I have tried this several times and the camera has run a firmware update but is still offline. I have restarted the base station plus removed and reinstalled the app on my phone to no effect. My internet shows 20Mbps upload speed. The other two cameras are working fine but I'm out of ideas on this third one can someone please help.
Thanks in advance
Mark
Swap cameras around to see if it's the camera or location that's the problem. If it's the location, look for something that has changed, possibly a wireless device that uses the 2.4GHz band (not just WiFi) that has been moved to near the camera.
Thanks for your help.
You might want to move the cordless phone away from the base (or vice versa) to help minimize issues of interference. A few feet should be fine.
I've moved the phone, the cameras appear to be connecting quicker now.
Thanks again for your help.
