Live View Not Working
Reset base, reinstalled app. Not using subscription. After-the-fact videos are stored and viewable, but no real-time.
Are the cameras AC-powered or solar powered? If they are, try removing the power cable.
They are solar powered. I can disconnect the power cables (it's still dark out so will wait till daylight), but for how long? A second? A minute? If that solution works, do I have to constantly reconnect/disconnect the power?
With power disconnected, still doesn't work. Growl...!
You could try a hardware reset of one of the cameras, and see if that resolves it.
- remove the camera from your account
- open the camera and press the sync button inside until the camera LED flashes amber (~15 seconds)
- add the camera back to your account
I could try that when I get a chance, but why would all four of my cameras have the same problem? Hasn't anyone else had this problem?
I haven't seen these problems reported by other Pro 3 owners. Several Pro and Pro 2 owners have reported similar symptoms, but those are EoL cameras and the Pro 3 is not.
Still, I suggest trying the hardware reset on one camera and see if that helps. You could also get a single-camera subscription for a month and then try Arlo support.
