I want to manage 2 SmartHub's (VMB4000, VMB 4540) in a single app.
I have a location that has Arlo PRO 2 cameras and a VMB4000 SmartHub already setup. I have another location that I am setting up Arlo PRO 3 cameras and a VMB4540 SmartHub. Can I manage both SmartHubs with my existing APP. If so how do set it up?
Steve
Yes…you can run multi bases in diff locations off the same app.
Go to the main device page ( that shows cameras)
at bottom, ADD Device
add the new base and then add cams to the new base
After in settings/devices you will see the two bases
