I have a Pro 3 flodlight
  • 20 Replies
  • 1230 Views
johnmharrod
When I try to add to my system.
I get one Blink - blue light.
my app can not find. I even have tried to manually sync.
could the camera be (end of life)?
johnmharrod
Turns out I just needed a new battery - question for group - is there anyway to check battery life?  Or is there a rule of thumb for replacing batteries?
thanks
JH
20 REPLIES 20
BrookeN
Have you tried to preform the reset on it before trying to onboard it?
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
johnmharrod
Yes - I have tried the factory rest - no success.
@johnmharrod wrote:
Yes - I have tried the factory reset - no success.
This was using the sync button inside the camera?  Removing/readding the camera is supposed to work also, but I think it's best to use the sync button. If you did use the sync button, did you see the amber LED flash?
You could also try adding the camera from a PC browser (my.arlo.com) - that might help.
Some other aspects:
  1. If you use a VPN, then turn it off during the install
  2. if the camera isn't being connected to your main wifi network, then make sure the phone is on the same network.  Also make sure that the network doesn't isolate clients from each other (many guest networks do this by default).
johnmharrod
Never saw the amber light
same network
no VPN
How long did you hold down the sync button?
johnmharrod
45 seconds
@johnmharrod wrote:
45 seconds
Does removing and then reinserting the battery change the behavior?
johnmharrod
No
im going to pickup a new battery tomorrow. Cross my fingers..
johnmharrod
thanks
JH
You could monitor the battery voltage after charging since that will decrease slowly over time. Otherwise, you can just monitor the number of days between charges as a rough indicator as well as the battery percentage shown in the camera's settings. Remember that li-ion batteries have best life when maintained between 40-80%. Letting them fully discharge should be avoided.
Nothing built in.  You can track the time between recharges, that will give you some idea.  Though that does depend on weather and usage, so it is just a rough guide.
johnmharrod
New Question:
Camera now kinda works:
Durring the daytime everything is fine.
After dark and when motion triggers the spotlight: there is a short and kicks the camera offline. I then have to:
remove camera from app
reset camera
reinstall camera
Battery reads 94%
perplexed
thanks
Can you explain what you mean by  "There is a short"?
johnmharrod
A like an electrical short - I think
once the light comes on - the camera shuts down and is offline at that point.
Hope this makes sense?
Does this also happen when you turn on the light manually while livestreaming?
johnmharrod
Yes
@johnmharrod wrote:
Yes
Is the camera recently purchased (or still covered by warranty)?
johnmharrod
No - older camera
BrookeN
Are you still seeing this same behavior?
johnmharrod
Yes
I have given up and purchased a new camera.
  • 20 Replies
  • 1231 Views
