I have 3 pro, VMS4340P. All of a sudden 2 are offline. Changed batteries , arlo base blue
  • 5 Replies
  • 341 Views
cdkin37
5 REPLIES 5
Reboot the hub. Do the cameras appear offline when using the web client on a computer browser (my.arlo.com)?
cdkin37
I did shut down modem, has blue light, but only have 1 camera out of three that is not "offline". I do not understand how 2 are "offline"
What happens if you bring a camera closer to your hub?
78rm400c
I have the same issue with 1 camera and am trying to figure it out as well. I am away from the house for a while so it is a problem for me.
Something I had planned to do was to factory reset the camera once I’m home.
Give that a try and post if it worked.   Thanks
78rm400c
Hope this helps … I think I fixed it for my one that was offline. I deleted the camera from my account and then re-paired it again.  Doing it once for me seemed to have worked. It’s been about 24 hours but all is well so far.   One other thing I noticed is that the battery was very low also. Not sure if that had anything to do with it.
Good luck !
  • 5 Replies
  • 342 Views
