. All of a sudden 2 are offline. Changed batteries , arlo base blue
Reboot the hub. Do the cameras appear offline when using the web client on a computer browser (my.arlo.com)?
I did shut down modem, has blue light, but only have 1 camera out of three that is not "offline". I do not understand how 2 are "offline"
What happens if you bring a camera closer to your hub?
I have the same issue with 1 camera and am trying to figure it out as well. I am away from the house for a while so it is a problem for me.
Something I had planned to do was to factory reset the camera once I’m home.
Give that a try and post if it worked. Thanks
Hope this helps … I think I fixed it for my one that was offline. I deleted the camera from my account and then re-paired it again. Doing it once for me seemed to have worked. It’s been about 24 hours but all is well so far. One other thing I noticed is that the battery was very low also. Not sure if that had anything to do with it.
Good luck !
