I try to set up my cameras. I go to add new device. the next screen asks me to plugs in an ethernet cable into my smart hub or base station. I do not have either. I am trying to connect to wifi.
I had all 3 cameras as a device before. I have my doorbell as a device. But I could not add my last item, a flood light, so I removed all devices. Now the floodlight pick up my wifi, but the cameras won't.
I fixed my issue. Thank you.
To clarify what cameras you are having problems with, but you posted and listed Pro3. It needs to be connected to a Hub but the Pro3 floodlight can connect to your wifi. The Pro3 comes with a Hub and cable unless you bought it as a stand alone camera.
