I can not access videos in the hub storage! It says check your connection settings!
Need help with Arlo Pro 3.
I can’t access videos in the hub storage. It says check your connection settings. I think connection is ok.
I am using IOS, not Android
Visar,
Have you set up local storage as instructed here: How do I set up local storage backups on a USB device using my Arlo base station?
If you're remote and attempting to view local storage, be sure you've followed these instructions: What is Direct Storage Access and how do I use it?
