  • 1 Reply
  • 1109 Views
larserso
I have a Netgear M1 mobile router that is supposed to be prepared to work as hub for Arlo cameras. But somehow I don't get it to work. In the Netgear app I can sync the camera correctly and it shows correctly under units. Then I am told to go to the Arlo app to connect the M1 as a hub (the choice, translated from Norwegian, is: Choose wireless Arlo with mobile router and follow the instructions) and then connect the camera to the M1. But in the Arlo app I can't find a choice to add wireless Arlo and when I try to set up a new base station or hub it doesn't find the M1. Is this no longer possible or what do I do wrong?
The M1 has the problem as earlier attempts to integrate Arlo into router firmware - the frequent updates to Arlo just didn't mesh with the infrequent router updates so it was booted. There's currently no way to use the M1 as a base station and likely never will be again.
  • 1 Reply
  • 1110 Views
