You need to adjust the SENSE level in the MODE you are arming with...
Goto Mode/pick base, EDIT ARMED ( > or pencil )
pick camera , then edit
under Record if Motion edit
slide setting to right for more or left for less sense level
back out so it saves
test
Only lower a couple % at a time and test as you don't want it to low to detect people
test
These cameras suck. The worst camera Arlo ever made. I sent all my Pro 3’s back. Customer support is little to none.
