How do I get full screen image on iPhone?
Hi roncorti,
Could you clarify on what problem you're exactly having? Are you not able to see on full screen when viewing on live stream? And what iPhone device are you using? Do you have a screenshot where you're not able to see in full screen?
Thanx for the response.
Do you have Two-Step Verification enabled on your account? Could you provide the screenshot that's showing on both your iPad and your Mac desktop?
I don't use two step verification.
I took a screen shot of the second message, but haven't figured how to include it on this doc. As I indicated it says in big letters ACCESS DENIED. Also the first message goes away so quickly I can't save it or read it
Click the paperclip at the bottom of this screen and navigate to the image you want to upload.
Well hidden, don't you think?
Just another user
@roncorti Your screenshot is a crossword puzzle.
Yea that worked never saw that error but that is what JessicaP needed .
Thanks for that screenshot, roncorti. From looking at that screenshot, it looks like you have Two-Step Verification on your account already.
When you log in, you should be prompted to enter a one-time code to access your account, which you can receive through push notification on your trusted iOS/Android device, SMS text message, or email.
If you're not receiving any code or it does not prompt you, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
