House to Guest house.
I have a new Pro 3 system with 3 cameras in my house, hooked it up, works fine.
But I also have a guest house that is approximately 175 feet from the main house... too far away for the cameras to be recognized if I want to add them down there. I do have a CAT 6 cable running between the two houses. I would like to put two cameras in that guest house. What is the best way to do this and what would I need hardware wise to do it. Currently that Cat 5 is plugged into my router in the main house but is plugged into nothing in the guest house.
Love to work this out.
Just add another system in the guest house and power/ethernet same.... add them to you current setup ( add device )
All will appear on one login.
