Arlo Pro 3 live streamed continuously to 3 monitors at the same time
I want to install an Arlo Pro 3 to monitor my front yard. I want to continuously stream live video to 3 flat screens setup in different parts of my home so no matter where I am in my home, I can see what is taking place out front. I have high speed internet with strong WiFi signal.
Can I do this with Arlo products?
If not, what do you recommend.
Thanks.
You can subscribe to CVR (continuous video recording) so the stream can be monitored but 3 screens could be a problem. Assuming you'd be using a computer or mobile device at each screen you'd need one to use the primary account and then two other email addresses that have been granted access. I can't speak for whether the accounts that have been granted access can stream CVR or if having one account viewing blocks the others.
What might be a better solution would be to use an HDMI splitter (or whatever cable type you're using) to drive all 3 screens from a single source. That would eliminate the software complexity.
