Hard wiring newer cameras (Pro3/Ultra) + compatibility with VMB3000
  • 4 Replies
  • 1785 Views
  • 2 Likes
FabQuadrozzi87
Hey guys, hope you’ve had a great festive period.
I’m currently in a dilemma at the moment as my original Arlo cameras, the batteries constantly need charging (no matter the sensitivity or video quality) every 2-3 days.
I’m essentially looking to upgrade to the Pro3 or Ultra but don’t know their compatibility with my original base station (VMB3000), is this compatible or not?
Secondly, ideally I want to have something that I can have externally to be hard wired (outdoor power cable) is there such a thing developed yet for arlo?
Many thanks for any help guys
ddavtian5
From Pro 3 FAQ:
"The Arlo Pro 3 camera is compatible with VMB5000, VMB4540, VMB4000, and VMB4500. It is not compatible with VMB3500 or VMB3000."
I think the same is true for Ultra.
You can have external power starting with Pro 2. I have few connected to power, and few using solar panels.
ddavtian5
From Pro 3 FAQ:
dcfox1
Just to add if you do upgrade get the Smart Hubs VMB4540 or 5000 so you can view local recordings through the app if you want. Here is a detailed breakdown on each hub or base.
What is the difference between each Arlo SmartHub and base station?
FabQuadrozzi87
Am I right in saying you can use the VMA5600C charging cable for the Arlo pro 3 cameras?
FabQuadrozzzi87,
Yes, the VMA5600C is designed to be used with Arlo Pro 3. For more information, take a look here: Outdoor Magnetic Charging Cable (25 ft.)
  • 4 Replies
  • 1786 Views
  • 2 Likes
