Google Chrome, I have 2 new Pro 3 cameras. Can not replay a recording on Google Chrome.
  • 5 Replies
  • 3162 Views
rseutter
I have 2 new Pro 3 cameras and 3 older Pro cameras. Google Chrome will not allow me to replay a recording from the new cameras. Error message is "this video will not replay in this browser" I can replay from the older cameras on Chrome but not the new ones. I can open the camera and view live but not a recording. What do I need to change to make the recordings from the new cameras replay?? Replay works on my iPad and iPhone, but not the computer.
Thank you
Thank you
If you are using a Windows PC, try the Edge browser.
Chrome and Firefox don't support 2K/4K HEVC video.  Edge will support it if you have HEVC hardware support in your PC (most newer ones do).  You might also need to get an HEVC extension for Edge from the microsoft store.  Unfortunately, Microsoft has decided to charge a bit for it recently.
5 REPLIES 5
Thank you
dcfox1
@rseutter  Edge works for me now on a tablet, It did not several months ago but not sure what update changed it but 2K is now fine. On my PC with a graphic card it always worked as @StephenB  said.
Before I enabled Zoom and Tracking that made the recording 1080 instead of 2K if you want to try it as a work around.
rseutter
Thank you, I tried Edge and the replay works. Guess I have to start liking Edge, not a big fan in the past. Thank you for the information.
rseutter
Thank you, Edge is working.
I only use it for Arlo now.  However, I do think the new Chromium version of Edge is pretty good (and you can install Chrome browser extensions, which I think is a good thing).
I suspect it would also increase your privacy.  Though I'm sure Google knows more about me than I do, and I don't think that will change if I drop Chrome.
  • 5 Replies
  • 3163 Views
