Hi,
Should it be possible to see the library when you have a friend invite with full access? If yes, what could have gone wrong?
Do you have a subscription, or are you using direct access to local storage?
The friend should be able to see cloud storage, but not local storage.
Only local storage. Haven’t been able to start a subscription yet. Have another open case for that. Thank you!
According to the webpage the friend with the invite should se recordings/library!!? So how do We get it to work?
Only cloud storage. The friend cannot see local storage.
