Any new product updates coming that will allow the cameras to filter out floating spider webs? Not on the camera or the lens in any way. Just one or two strands that float a foot or two in front. It catches as a 'Vehicle', an 'Animal', and other. I have worked the configuration for filtering out and also reducing sensitivity down to 20 or less. Still just constantly generates Motion detection. This would seem like something fairly simply to filter out. I have read all similar posts over the years and it is a recurring theme. Any update on Arlo's position on this? Thanks!
The only fix is to remove the spider web (or the spider).
