Login problem on an android device
  • 1101 Views
Tb51
In the past couple of weeks I'm having a problem logging into my arlo account.
I reset the password twice already, and re-installed the app, but nothing helped.
I think that I have a problem with the 2fa, but I'm not receiving any email after trying to log in.
Any thoughts?
BrookeN
Can you try another method for the 2FA? It should give you that option, can you try that and let me know if it works.
Tb51
How can I switch to a different method? I can't even access the app...
BrookeN
I have reached out to support regarding you being locked out of the account. They will be reaching out to you as soon as possible.
  • 1102 Views
