Fast discarded battery
  • 1 Reply
  • 823 Views
Vasse25668
The battery discharge very fast. I hav a new battery, but ther is no difference. The camera is a Arlo pro 3 series number 1.060.13.0_23_19c4503.
can you help me.
Best answers
  • jguerdat
    Is the camera connected to a solar panel? If so, disconnect the panel from the camera to see if that helps.
    Other ways to cause the battery to rapidly discharge are signal strength/quality issues as well as excessive recording and live viewing. For the former, move the camera closer to your hub to see if the drain improves. For the latter, add up the total number of minutes per day the camera records. You may have to disable activity zones to get a true count since the servers may be discarding videos that are deemed outside the zones.
  • 1 Reply
  • 824 Views
