Only one of my cameras says need to update the firmware but always fails with error 4208, I already reset everything, restart base and camera, put closer, put far.
the base firmware is 1.25.1.0-1687-1f1c874 hardware VMB4540r2, the camera hardware is H9 and firmware update shows 1.080.14.2-6-b1306bd.
any suggestion how to fix it?
Still not working
Uninstall the app and then reinstall the app, then do a reset on the camera and re-onboard it and see if that resolved it.
Sorry, it did not work, I already tried it as well. I saw in another post that a private message solved it.
thank you
Hi all, sorry any other suggestions?
thank you
Were you able to update the Pro 3 on the account?
Hi, not yet. After 5 minutes trying to update, I have an error 4208 or 4209.
I.m still waiting a solution for only one camera.
thank you
Do you have another device you can try to update this device on by any chance?
