  • 4 Replies
  • 2572 Views
Wegentryjr1
So did they remove the option to erase the SD card or what? I cannot find it now. I have a bunch of videos that I would just as soon delete. I guess they’re not getting anything since they will be over written, but still…I don’t appreciate functionality being taken away from me.
You erase it by reformatting it - that control still exists at the bottom of the local storage page in the web ui.  In the iOS app, you press on "Storage Status" , and you'll find both eject and format controls there.
Edinburgh_lad1
It's still there. I suggest you check the manual to double-check where it is.
Wegentryjr1
Nope. Unless it has been moved.
Wegentryjr1
Ahh.. so it was moved. Thank you
  • 4 Replies
  • 2573 Views
