Hello.
If the cameras are next to each other, there could be interference - try separating them by several feet. Also, try bringing the cameras closer to the base to see if that helps. Finally, try movinmg the base away from the router as much as practical.
@Rjsmts wrote:
Does anyone have any other suggestions for troubleshooting?
Have you tried swapping the camera with one that doesn't have this issue?
Then see if the problem stays with the camera or the location.
I tried all suggestions, and still having issues.
I just had the battery charged to 100%, and it lost charge within a day, even though it's not working or connecting. I am at a loss. It will charge up just fine and have 100%, and I can hear it, like the sounds it's making like it's working and the light comes on as if it's recording something, but I keep getting the message when I'm on the device and hit play, it times out and cannot connect. It is just this camera.
Any other suggestions? Thank you so much.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Was this ever resolved
Hola tengo el mismo problema me pasa lo mismo que comentaste, pudiste solucionar el problema? Me podrías ayudar por favor
Hello, I have the same problem, the same thing you mentioned happens to me, were you able to solve the problem? Could you help me please
