Connecting to Starlink??
I need this to connect to my Starlink which is only wifi based, how can we remedy this since this is going to be the new normal hopefully? Is there an inexpensive converter from wifi to ethernet?
The way to connect to a wifi based system only is to add a wifi extender with an Ethernet port...
then you can use the ethernet port for your base unit.
Many in $50 range or so...
