Cannot set up subscription
  • 5 Replies
  • 2675 Views
monkeybadger
Hi,
I bought an Arlo floodlight before Christmas and set it up fine, including setting up a 3 month trial.
Now that it has ended I cannot setup a paid subscription, the app just does not let you get past the VISA screen. I tried different cards but it was the same outcome. I finally tried in a browser and although no error appeared, when I checked the developer console, there is an error coming back from the server
{"data":{"error":"8030","message":"You entered an invalid zip code. Please update and try again.","reason":"Postal code is invalid"},"success":false}
The problem is I'm using a UK post code, and it does not accept it. So I tried different ways, including no space etc, but no luck. I can see I'm not the only person to have this issue, however I cannot see a resolution other than "someone will reach out
monkeybadger
The solution was to change the postcode I was using (Northern Ireland) to a London one. Billing was unaffected by using an incorrect postcode.
5 REPLIES 5
monkeybadger,
Have you contact the support team regarding this issue? Do you have a ticket number I can reference and request a status update?
monkeybadger
Hi, no. Where do I do that?
monkeybadger,
Take a look at the link here for contact options: https://www.arlo.com/en-us/support/contact.aspx
monkeybadger
Thank you. I have raised case 42341776
monkeybadger
  • 5 Replies
  • 2675 Views
