Cannot charge
  • 11 Replies
  • 3197 Views
Gk58
Cannot get my pro 3 to charge
11 REPLIES 11
ShayneS
Hi @Gk58
Are you still experiencing this issue?
Gk58
Still not charging. Any recommendations?
Gk58
Still not working
@Gk58 wrote:
Still not working
Some more details would help.
  • Is this a new camera, or an old one?
  • Are you charging it outdoors?  If so, what is the temperature?
  • Was the battery completely discharged when you first tried to charge it?
  • Have you tried another charger?
  • Have you tried another cable (if you have one)?
  • Do you have any other Pro 3 cameras?  If so, have you tried swapping the battery with one in another camera?
Gk58
I bought a refurbished arlo pro 3 on Amazon. It appears new and in good shape.  Came with magnetic charging cord.
Successfully charged camera after purchase.  Camera worked fine.   Tried charging outside after battery was at approx 30%.  Couldn’t get it to charge, brought it inside and connected charger to it.  After a few attempts got it to charge. Again camera worked ok.  When battery reached approx 30% I brought it inside and attempted to charge it. No luck.
I currently own 5 arlo pro 2 cameras and the single pro 3.  Batteries and charger are not interchangeable.  I only have the single charger and battery that came with the camera.
The battery and cable are not interchangeable.  But the Pro/Pro2 USB charger will work with the Pro 3, so you might see if using that charger (or any other 2 Amp USB charger you have) makes any difference.
Gk58
I have 2 arlo usb chargers.  Tried both of them. Both work with arlo pro 2 cameras, nether work with the pro 3.
Then it could be the camera, the cable, or the battery.  No easy way to tell.  You might open the housing, and make sure the contacts are clean.
Can you return it to the seller?
Gk58
No I tried that already.  The battery lasted about 3 weeks after the first charge.  I got about 3 weeks out of the second charge. Total of 6 weeks.  Amazon replied that they would have issued a refund within 30 days of purchase.    I am very disappointed in this product.  First issue is without a subscription with arlo you get NO recordings with the pro 3.  With the Pro 2 you get 7 days of recordings.  Didn’t know when I purchased the camera.  I thought I was upgrading with a better camera.  I was wrong.  Second thing is without a subscription arlo support is virtually nonexistent, with exception of this communication.  The virtual chat system is absolutely useless. To the point I will never purchase another netgear product.
Gk58
I did remove the camera from the housing and looked at the contacts.   All look good.
FYI, Netgear divested Arlo back in 2018.   They have no ownership in Arlo (they didn't retain any stock).
  • 11 Replies
  • 3197 Views
