Cannot Logon via the Google App and the unprofessional "Oops" message
Simply stated: the Google App is unable to connect and get the "Oops... Try Again" message.
Summary: 2FA is enabled, long time customer, PW is correct as I can logon to the web and I do have tech skills
My experience:
- For a paid for service the support experience is non-existent.
- Four support tickets issued and handed off to every team possible team but never finding someone who has any technical skill
- Substandard/circular Tech Sup playbook being followed - if users cannot access logon to first level systems via the App why do you instruct users to use the App to Contact Tech Sup?
- No direct means to access US telephonic support
- Arlo Leadership: you need to invest in SW QA team - your application code is sub-standard (change your "Oops" message too - aren't you publicly traded or are you trying to be cool?); if it is not the app GUI then you need to look at the calls between the App and the Credentialing or Access Mgmt DBs; you need to empower your support reps.
Takeaway:
Caveat Emptor
Are you having an issue logging in to the Android Arlo Mobile app?
Which version of the Arlo mobile app are you using on your phone?
