  • 5 Replies
  • 1404 Views
jlr210
Can you use any USB power adapter for the Pro 3
5 REPLIES 5
Pretty much, though you do need the magnetic cable of course.
The Arlo indoor charger is 5 volts, 2 amps.
jlr210
Hi Stephen,
Sat, Apr 2 at 3:24 PM
So all my apple 5.1v and 1 or 2a are ok :).
After months of testing locations and activity zones (which I learned work best when you cross the beam), with and without ac power, and after the free subscription months I’m ready to subscribe and will get 4 magnetic cables (which I think all come with the adapter) and a 4th camera .
Any idea if anyone you know makes a short 3 foot cable like the ones that come originally with the cameras? Wasserstein doesn’t have one.
Also, can volume in 2way mode be increased, besides volume control on the camera setup?
Activity seems to only effectively 15-20ft away?
Lastly when I’m out of town how many seconds is the delay when I get an alert?
It’s very kind to hear from a”user” of the system. Many thanks,
Jim
The 2a for sure. Not so sure on the 1a.
Mine are all Arlo, so I have no direct experience here.  The shortest I've seen on line is 8 feet.
The passive infrared (PIR) sensors have a nominal range of 20-25 feet.  Though some objects (vehicles for example) often are detected when further away.
Only using whatever controls are on the app device (or PC).  That can be an issue, particularly on Samsung phones.
The alerts always come via the Arlo cloud, so the delay while on the road won't be much different than the delay when home.  It is somewhat variable, but I think in my case it's usually a few seconds.
jlr210
Last questions:
1.  I see the Arlo add is touting 6 months battery life on the Ultra 2, do you know what the typical life is on the Pro 3?
2. Do you get all the benefits and features whether you're on battery or ac power when you're a subscriber?
Thanks again,
Jim
Battery life tends to get overstated (also by competitors).  My cameras generally get about 2 months.   Your experience might differ, it depends a lot on how much motion there is in the field of view.
Thanks again,
There is a foresight feature that requires AC power.  In that mode, the camera is always capturing and buffering video.  When the motion is detected, the recording includes a couple of seconds before the motion detection.  Foresight doesn't require  a subscription.
CVR (continuous video recording) is its own subscription (not part of Secure/Secure Plus), and it also requires AC power and a base station.
Activity zones are processed by the camera when you are on AC power, but are processed by the cloud when you have a subscription and are on battery.
  • 5 Replies
  • 1405 Views
