Can i buy the adjustable short mount in black?
  • 4 Replies
  • 1075 Views
Aske
Hi
Can i buy the adjustable short mount in black? Got 2 in the package with 4 cameras, so would like 2 more?
Do you mean these?  https://www.arlo.com/en-us/accessories/VMA1000B-10000S.html
Aske
no unfortunately, got 2 of https://www.arlo.com/en-us/accessories/VMA1001-11100S.html in black included in the package but can not find them anywhere.
I'm not seeing a huge difference, both have 2 inch extensions and both are swivel mounts.
The cameras use standard 1/4 inch screw mounts, so almost any mount will work - no need to stick with Arlo.
Aske
they are considerably smaller, so would like them, but it will probably just be the others. Many thanks for the help.
  • 4 Replies
  • 1076 Views
