  • 14 Replies
  • 1474 Views
MikCar
My cameras stopped recognizing animals since some time back last year. I’ve read others posts regarding exactly the same issue.
So when smart messages for animals are turned off, the cameras can’t recognize animals, it’s always shown as either person or just motion. It doesn’t matter whether it’s a bird, cat or raw deer. It’s annoying to get alerts of a person and it’s only a cat…
However, if I turn on the smart messages for animals the cameras recognize animals.
I want to have it turned off and not get alerts for animals for obvious reasons. But as it is now I get false alerts of persons when animals. This must be a software issue I’d like you to look into please! Thanks!
Best answers
  • ShayneS
    Hey @MikCar
    Just wanted to let you know the team is aware of these instances of misclassification and actively investigating. I'll continue to provide updates here when received
14 REPLIES 14
ShayneS
Hi @MikCar
Does this happen with all your devices as well?
MikCar
Yes
ShayneS
Hi @MikCar
Would you be able to provide 2–3 specific dates and times when an animal was incorrectly labeled as "Person" or "Motion" (the more exact the better, even approximate times help).
MikCar
Ok sure. Found two with just motion, cat and raw deers. Sunday May the 10th at 4.53 am (CET) and May 15th 06.18 am. Also a cat marked as person May 11th at 00.28 am.
The best example is unfortunately not stored in the library anymore, so it must have been more than 30 days then. It was a raw deer moving in slowly and close to the camera and marked as a person.
ShayneS
@MikCar
Im still waiting for more feedback from the team, also wanted to see if you are still experiencing this?
MikCar
Ok thanks, yes I’m still experiencing the same problem
Ljoublanc
... instead, it tags them as 'motion detected', and this unfortunately means that I can not switch off notifications (without disabling other motion too).
Is there a software update or similar planned for this?
ShayneS
HI @Ljoublanc
Thank you for the feedback. When did this symptom start occurring for you?
Ljoublanc
Since we installed the camera last week.
ShayneS
@Ljoublanc
Are you still experiencing this as of today? There was an update that was done on the backend the other day that should have helped with similar symptoms. If you can monitor this, and let me know if it still occurs.
Ljoublanc
Yes, still happening At 4 AM today 10th October; I'll keep and eye out to see if it improves.
Ljoublanc
Still happening this weekend.
ShayneS
Hey @MikCar
MikCar
Ok, thanks for updating!
  • 14 Replies
  • 1474 Views
