Camera not recognizing animals
My cameras stopped recognizing animals since some time back last year. I’ve read others posts regarding exactly the same issue.
So when smart messages for animals are turned off, the cameras can’t recognize animals, it’s always shown as either person or just motion. It doesn’t matter whether it’s a bird, cat or raw deer. It’s annoying to get alerts of a person and it’s only a cat…
However, if I turn on the smart messages for animals the cameras recognize animals.
I want to have it turned off and not get alerts for animals for obvious reasons. But as it is now I get false alerts of persons when animals. This must be a software issue I’d like you to look into please! Thanks!
Yes
Hi @MikCar
Would you be able to provide 2–3 specific dates and times when an animal was incorrectly labeled as "Person" or "Motion" (the more exact the better, even approximate times help).
Ok sure. Found two with just motion, cat and raw deers. Sunday May the 10th at 4.53 am (CET) and May 15th 06.18 am. Also a cat marked as person May 11th at 00.28 am.
The best example is unfortunately not stored in the library anymore, so it must have been more than 30 days then. It was a raw deer moving in slowly and close to the camera and marked as a person.
Im still waiting for more feedback from the team, also wanted to see if you are still experiencing this?
Ok thanks, yes I’m still experiencing the same problem
... instead, it tags them as 'motion detected', and this unfortunately means that I can not switch off notifications (without disabling other motion too).
Is there a software update or similar planned for this?
Since we installed the camera last week.
Are you still experiencing this as of today? There was an update that was done on the backend the other day that should have helped with similar symptoms. If you can monitor this, and let me know if it still occurs.
Yes, still happening At 4 AM today 10th October; I'll keep and eye out to see if it improves.
Still happening this weekend.
Hey @MikCar
Just wanted to let you know the team is aware of these instances of misclassification and actively investigating. I'll continue to provide updates here when received
Ok, thanks for updating!
